LPC2106 (caratéritiques spécifiques de LPC2106)
Datasheet des LPC210x
Doc du core ARM7TDMI
Programmateur et debuggeur JTAG:
JTAG Wiggler
JTAG olimex
Compilateur et IDE:
WinARM
CrossWorks for ARM
EW-ARM
GCC
GNUARM
Desciption du site olimex:
# CrossWork for ARM (so far most recommended by us) C compiler and debuger from Rowley Associates, this is the easiest to use package we have tested, works smoothly with ARM-JTAG and programs both Flash and RAM on LPC21xx and many other ARM microcontrollers.
# EW-ARM C compiler and debugger (free for assembly language, 16K limit for C) from IAR Systems. Latest release can program LPC21xx Flash. C-SPY driver for ARM-JTAG have some glitches on newer and faster computers and does several crashes before connect to target. It works fine on older and slower computers though. IAR either is not able to support Wiggler either is interested to not support it to may sell their expensive J-LINK USB tool.
# GCC C compiler from Macraigor Systems. Works smoothly with ARM-JTAG but can't program Flash and user can compile debug programs in RAM then re-build for Flash and use Philips' RS232 bootloader. It may be tricky to setup working environment by unexperienced user.
# GNUARM another GCC toolchain from Arius.
forums et newsgroups :
http://groups.yahoo.com/group/lpc2000/
wiki arm : http://www.open-research.org.uk/ARMuC/
