Projet VHDL : multiplicateur séquentiel
Messagede Keul le 13 Déc 2005 20:22
un gros problème en VHDL : je n'arrive pas à faire une pauvre addition 'alors que dans un autre exercice à coté, ca fonctionne nickel)
en gros, voila les endroits concernés :
multiplicand : in std_logic;
multiplier : in std_logic;
Signal x : std_logic_vector(7 downto 0);
Signal y : std_logic_vector(7 downto 0);
Signal z : std_logic_vector(7 downto 0);
variable n : integer := 0;
x(n) <= multiplicand;
y(n) <= multiplier;
z <= z + (x(n) and y(0));
et quelque-soit els trucs que je fait, z reste égal à 0 :|
pour le code complet :
Code: Tout sélectionner
-- ***** 8 bits Sequential Multiplier *****
-- ********** with serial inputs **********
library IEEE;
        use IEEE.std_logic_1164.all;
        use IEEE.std_logic_arith.all;
        use IEEE.numeric_bit.all;
        use IEEE.numeric_std.all;
        use IEEE.std_logic_unsigned.all;
-- **** entity definition ****
entity MulKeulSerial is
   Port ( clock : in std_logic;
          start : in std_logic;
          result : out std_logic;
      test1 : out std_logic;
      test2 : out std_logic;
      test3 : out std_logic;
      test4 : out std_logic;
          ready : out std_logic);
end MulKeulSerial;
-- **** architecture definition ****
architecture RTL of MulKeulSerial is
begin
   process(clock, start)
   begin
      if (rising_edge(start)) then
         x <= "00000000";
         y <= "00000000";
         z <= "00000000";
         n := 0;
         ready <= '0';
      elsif (rising_edge(clock)) then
         n := 0;
         if (n < 8) then
            y(n) <= multiplier;
            test1<=z(0);
            test2<=z(1);
            test3<=z(2);
            test4<=z(3);
            if(n >= 1) then
               z <= z + (x(n-1) and y(1)); end if;
            if(n >= 2) then
               z <= z + (x(n-2) and y(2)); end if;
            if(n >= 3) then
               z <= z + (x(n-3) and y(3)); end if;
            if(n >= 4) then
               z <= z + (x(n-4) and y(4)); end if;
            if(n >= 5) then
               z <= z + (x(n-5) and y(5)); end if;
            if(n >= 6) then
               z <= z + (x(n-6) and y(6)); end if;
            if(n >= 7) then
               z <= z + (x(n-7) and y(7)); end if;
         end if;
         result <= z(0);
         --z <= srl shift right logical(z);   dosen't work, use that instead
         z(0)<=z(1);z(1)<=z(2);z(2)<=z(3);z(3)<='0';
         n := n + 1;
         if(n > 7 and z = "00000000") then
            ready <= '1';
         end if;
      end if;
   end process;
end RTL;
Il existe 10 types de personnes : celles qui savent compter en binaire et celles qui ne savent pas.
Keul
Développeur
Développeur
Messagede Keul le 15 Déc 2005 13:38
Plus la peine de vous embêter, j'ai trouvé le problème :)
(en fait, fallais remplacer des "Signal" par "variable")
Keul
Développeur
Développeur
Messagede marsu le 15 Déc 2005 22:12
Effectivement, les variables sont affectées instantannément mais pas les signaux...
Marsu
BLOG d'electronique, informatique, humour, sexy, ... :
http://forire.free.fr
marsu
INSATIABLE
INSATIABLE
