I am working on a FleXDS evaluation board of the DSP TMSC5509A from FleXDS.
The board contains the three terminals McBSP's ports.
To communicate with Windows hyperterminal, I use the software UART minidriver
from the Texas Instrument DDK 1.20. The exemple of the Software UART provided in the DDK works well.
But, in my project, I want to use two McBSP's ports. To test both McBSP's ports I have changed
the exemple of the Software UART in the DDK.
I declare two UART handle in the file "uarttest_params.c":
Code : Tout sélectionner
UARTHW_MCBSP_Params uartMcbspParams = {
MCBSP_PORT0, // mcbspId
DMA_CHA2, // dmaRxId
DMA_CHA3, // dmaTxId
120000000, // mcbspClkIn
115200, // baud
UARTHW_MCBSP_IER_MASK_DEFAULT,
// This structure must be specified in the device driver's device params
// pointer in the DSP/BIOS Configuration Tool.
UARTMD_DevParams uartDevParams = {
UARTMD_VERSION_1, // driver version number
FALSE, // packedChars
&uartMcbspParams // uartHwParams
// This structure holds the McBSP parameters and is referenced by the
// device parameters structure.
UARTHW_MCBSP_Params uartMcbspParams1 = {
MCBSP_PORT1, // mcbspId
DMA_CHA4, // dmaRxId
DMA_CHA5, // dmaTxId
115200, // baud
UARTMD_DevParams uartDevParams1 = {
&uartMcbspParams1 // uartHwParams
I register both UARTs (I name it "uart" and "uart1") in the DSP/BIOS.
In the file "uarttest.c", I create input and output channels in the echo() task:
GIO_Handle inChan, outChan, inChan1, outChan1;
Char buf[12] = "Hello World ";
Uns size = 12;
inChan = GIO_create("/uart", IOM_INPUT, NULL, NULL, NULL);
outChan = GIO_create("/uart", IOM_OUTPUT, NULL, NULL, NULL);
inChan1 = GIO_create("/uart1", IOM_INPUT, NULL, NULL, NULL);
outChan1 = GIO_create("/uart1", IOM_OUTPUT, NULL, NULL, NULL);
When I run the program, inchan1 and outchan1 are NULL pointer, so the communication by the port MCBSP_PORT1 doesn't work.
Do tou have any solution to this problem?
In other words: Is-it possible to realise a multi device asynchronus communication with the McBSPs port? If yes how it can be done?
Thank you very much for your reply.
Olivier
