Ensuite:
Code : Tout sélectionner
putchar(read_adc(0));
putchar((char) read_adc(0));
Je crois tu confonds PIC et AVRau pic
Effectivement, je pensais que tu parlais du CAN interne.le probleme c'est que j'utilise un CAN 12bit externe au pic est qui fonctionne en liaison SPI je me trompe peut etre mais ce que tu me dis c'est pour le CAN interne non??
Digital voltmeter using an
Analog Devices AD7896 ADC
connected to an AT90S8515
using the SPI bus
Chip: AT90S8515
Memory Model: SMALL
Data Stack Size: 128 bytes
Clock frequency: 4MHz
AD7896 connections to the AT90S8515
[AD7896] [AT9S8515 DIP40]
1 Vin
2 Vref=5V
3 AGND - 20 GND
4 SCLK - 8 SCK
5 SDATA - 7 MISO
6 DGND - 20 GND
7 CONVST- 2 PB1
8 BUSY - 1 PB0
Use an 2x16 alphanumeric LCD connected
to PORTC as follows:
[LCD] [AT90S8515 DIP40]
1 GND- 20 GND
2 +5V- 40 VCC
3 VLC
4 RS - 21 PC0
5 RD - 22 PC1
6 EN - 23 PC2
11 D4 - 25 PC4
12 D5 - 26 PC5
13 D6 - 27 PC6
14 D7 - 28 PC7 */
#asm
.equ __lcd_port=0x15
#endasm
#include <lcd.h> // LCD driver routines
#include <spi.h> // SPI driver routine
#include <90s8515.h>
#include <stdio.h>
#include <delay.h>
// AD7896 reference voltage [mV]
#define VREF 5000L
// AD7896 control signals PORTB bit allocation
#define ADC_BUSY PINB.0
#define NCONVST PORTB.1
// LCD display buffer
char lcd_buffer[33];
unsigned read_adc(void)
unsigned result;
// start conversion in mode 1
// (high sampling performance)
NCONVST=0;
NCONVST=1;
// wait for the conversion to complete
while (ADC_BUSY);
// read the MSB using SPI
result=(unsigned) spi(0)<<8;
// read the LSB using SPI and combine with MSB
result|=spi(0);
// calculate the voltage in [mV]
result=(unsigned) (((unsigned long) result*VREF)/4096L);
// return the measured voltage
return result;
void main(void)
// initialize PORTB
// PB.0 input from AD7896 BUSY
// PB.1 output to AD7896 /CONVST
// PB.2 & PB.3 inputs
// PB.4 output (SPI /SS pin)
// PB.5 input
// PB.6 input (SPI MISO)
// PB.7 output to AD7896 SCLK
DDRB=0x92;
// initialize the SPI in master mode
// no interrupts, MSB first, clock phase negative
// SCK low when idle, clock phase=0
// SCK=fxtal/4
SPCR=0x54;
// the AD7896 will work in mode 1
// /CONVST=1, SCLK=0
PORTB=2;
// initialize the LCD
lcd_init(16);
lcd_putsf("AD7896 SPI bus\nVoltmeter");
delay_ms(2000);
lcd_clear();
// read and display the ADC input voltage
while (1)
sprintf(lcd_buffer,"Uadc=%4umV",read_adc());
lcd_clear();
lcd_puts(lcd_buffer);
delay_ms(100);
unsigned char spi(unsigned char data)
