Error in VHDL code
Roberto Baena
Error in VHDL code
Message par Roberto Baena »
Hi!
I've written some VHDL code and I got the following error message:
Error: Can't resolve multiple constant drivers for net sensor_sigte[1] at Simulacion_SSI.vhd(104)
Can anybody help me with this?
The code is posted below. If you need the complete program tell me and I'll send you. Of course I have posted here the part of the code I think is necessary for corrections.
Thanks!!!!!
ETAPA_ENVIO: process -- LÍNEA 104
begin
wait until (step=2);
case (sensor) is
when 1 =>
control <= "01";
sensor_sigte <= 2;
when 2 =>
control <= "10";
sensor_sigte <= 3;
when 3 =>
control <= "11";
sensor_sigte <= 1;
end case;
irq_aux <= '1';
step_sigte <= 3;
data_paralelo_out <= data_paralelo_aux;
end process;
SINCRO: process (CLK_48M, RESET)
begin
if (RESET='1') then
step <= 1;
step_sigte <= 1;
sensor <= 1;
sensor_sigte <= 1;
elsif ((CLK_48M'EVENT) AND (CLK_48M='1')) then
sensor <= sensor_sigte;
step <= step_sigte;
end if;
end process;
Hi Roberto,
Don't you forget the process signal ?
Example:
Code : Tout sélectionner
ETAPA_ENVIO: process (clk)
JP, newbie in VHDL
lamygale
Message par lamygale »
Hi
The cause is simple:
you have a signal that is driven in 2 process.
The VHDL cannot "understand" that.
In VHDL you must assign a signal in one and only one process.
You can read it in others process but not write in this signal.
Regards
marsu
INSATIABLE
INSATIABLE
Message par marsu »
Alors déja JP pour le
il n'est pas utile car il y a un "Wait UNTIL" et ça remplasse la liste de sensibilitée...
Le probleme vient du signal sensor_sigte qui est affecter dans les deux process. Ce n'est pas autorisé en VHDL.[/u]
marsu
INSATIABLE
INSATIABLE
Message par marsu »
Désole lamygale je n'avais pas vu ton message
Ok merci pour l'info ;)
JP, toujours newbie mais il se soigne
